Discussion topic: Another Sky Q keeps losing Internet connection thread
Message posted on 27 Jan 2024 05:27 PM
Message posted on 27 Jan 2024 05:32 PM
Re: Another Sky Q keeps losing Internet connection thread
@SlapHead wrote:
So read a few threads on the same issue, yet there doesn't appear to be a fix. My sky q box loses Internet connection maybe 15 times a day, yet my internet is NOT down. The box is hard wired to the router, I've tried changing the ethernet cable, I've reset the q box, I've made sure latest firmware is installed. Anything else I should do before leaving Sky and getting Virgin?
Hi @SlapHead
If you have no mini boxes turn off the Q box WiFi.
When Q boxes are connected by Ethernet you can then switch off all Q box WiFi.
On the main Q box and first carry out a Network reset with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router (or Sky router if on Sky Broadband). Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
As soon as it connects go into the Q box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
Message posted on 27 Jan 2024 06:00 PM
Message posted on 27 Jan 2024 06:04 PM
@SlapHead wrote:
Hi, thanks for reply. Already tried this many many times. The q wifi has never been on as don't need it. I am having to reset the network about 15 times a day. This only started recently. Been with Sky Q for over 3 years without issues until now.
Hi @SlapHead
Did you turn off the WiFi immediately following a Network reset on the main Q box?
Message posted on 28 Jan 2024 04:05 PM
