Discussion topic: An easier way?
This message was authored by AmandaR81 This message was authored by: AmandaR81
An easier way?
Hello, we just connected our 3rd sky q mini box. We thought if the boxes in the other rooms were on standby we could could seamlessly watch 2 mini boxes in our rooms of choice but we're having to switch stuff off at the wall in order to remove the "maximum number of boxes are in use" error screen. I use the sky remote to control the TV. It's a nightmare having to move furniture to get to the sockets. Any ideas? Much appreciated, Amanda
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: An easier way?
Try a reboot of the main box.
But smartplugs can be controlled remotely if needed...
I am just another Sky customer and my views are my own
Re: An easier way?
@AmandaR81
One tip is to always exit back to the Sky home screen with a live channel playing before putting a Mini in standby.
AmandaR81
Re: An easier way?
thank you @TimmyBGood and @PandJ2020
Re: An easier way?
Hi @AmandaR81
You certainly shouldn't have to turn the minis off at the mains.   Standby should be adequate.    If you still have the issue try a Reset Settings in the main Q box hidden menu.
