Discussion topic: Amazon constantly freezing
Message posted on 05 Apr 2025 06:33 PM
Amazon prime freezes every minute or so it's now unwatchable
Message posted on 05 Apr 2025 07:10 PM
Re: Amazon constantly freezing
Assume this is on your Q box @Bryan1964
