Discussion topic: Sky Q not working with new tv
Message posted on 04 Apr 2025 03:56 PM
I have recently bought 2 new tvs and the main sky q box doesn't work with either
i can connect ok but as soon as the hello screen disappears the picture keeps flickering and is impossible to watch sound is also on and off, I have downloaded latest software and used new hdmi cables and still the problem persists
I re plug the old tv and everything is fine ?
Message posted on 04 Apr 2025 04:26 PM
Re: Sky Q not working with new tv
Hi @KD30
First make sure that the Television is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which should work for all TV’s. See if this is any better
Message posted on 05 Apr 2025 07:31 AM
What model TV is it?
Which new cables did you get?
Does the same happen with both new TVs?
Message posted on 05 Apr 2025 09:27 AM
Already done this still have the same problem
its as of the sky box can't match the resolution of the new tvs
old tv works fine
Message posted on 05 Apr 2025 09:29 AM
One tv is TCL and the other is Samsung both work fine with the sky mini box but not the main sky q box
Message posted on 05 Apr 2025 02:48 PM
@KD30 wrote:Already done this still have the same problem
old tv works fine
What output res is the Q set to?
should be 1080i after that remote button sequence.
Every TV in the last ~20 years can accept that.
Message posted on 05 Apr 2025 07:31 PM
Very strange. I can't get to the bottom of it
