Discussion topic: Alyson70
Message posted on 14 Nov 2023 06:43 PM
Alyson70
Discovery+constantly buffering and losing Internet connection? Nothing wrong with my Internet
Message posted on 14 Nov 2023 10:05 PM
Re: Alyson70
Any buffering of the App on your Q box will be due to the Broadband signal that the Q box is receiving.
This can have no reflection on your internet; but just what the Q box is seeing.
You could try a Network reset on the Q box to if it will refresh the Connection.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Message posted on 15 Nov 2023 04:23 AM
Re: Alyson70
Thank you
