Discussion topic: Alternative to Sky Q multi room boxes
Message posted on 23 Jun 2024 12:44 PM
Hi, as the title suggests, I'm looking to see if there is an alternative to the mini boxes, we have 3 multi room boxes in the house but they are interfering with the Sky Broadband. The Internet is constantly dropping and I have been told from the Sky broadband forum that the multi room boxes are most likely the cause. I have seen some smaller Sky pucks advertised, can they be used with Sky Q and do they work similarn to the multiroom boxes as in boosting signal and causing issues etc.
Message posted on 23 Jun 2024 12:52 PM
Re: Alternative to Sky Q multi room boxes
You can't add stream pucks to Sky Q, it's one or the other I'm afraid.
Based on your current setup you'd need 4 stream pucks. For HD you need at least 25mbps & UHD 35mbps per puck.
If you have poor wifi you need to ensure there is a adequate signal to every puck otherwise you'll encounter problems.
Message posted on 23 Jun 2024 12:53 PM - last edited: 23 Jun 2024 12:55 PM
No, and no.
Stream pucks are simple WiFi client devices and have no hotspot or mesh functionality.
As @GD1 indicates, they cannot be in the same household as Q just because Sky doesn't permit that.
Message posted on 23 Jun 2024 03:51 PM
Thanks for the replies @GD1 & @TimmyBGood . The WiFi signal is good throughout the house, I have the router on a shelf on the stairs so it gives a good signal, that's tested with all the mini boxes unplugged. It looks as though the natural route would be to go with Sky Glass, do the pucks cost the same as the Sky Q multi room?
Message posted on 23 Jun 2024 03:57 PM - last edited: 23 Jun 2024 03:59 PM
@Mikemurg Pucks are loaned to customers for the duration of subscription at a cost of £39.95 each maximum of 6 allowed
in addition you need the monthly whole home subscription equivalent of Q multi room at £12/13pm
Message posted on 23 Jun 2024 04:57 PM
@Mikemurg wrote:Thanks for the replies @GD1 & @TimmyBGood . The WiFi signal is good throughout the house, I have the router on a shelf on the stairs so it gives a good signal, that's tested with all the mini boxes unplugged. It looks as though the natural route would be to go with Sky Glass, do the pucks cost the same as the Sky Q multi room?
Only if you're in the market for an overpriced TV.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 07 Oct 2024 05:19 PM
You could do what I do and turn the wifi off on the Sky mini boxes and connect them with ethernet cables (and the main Sky box) up to wifi access points on your existing wifi network. That way the Sky boxes think they are on a hard-wired network and they work perfectly. I've been doing this for years without a hitch - and they don't interfere with my home wifi because they aren't outputting wifi.
Message posted on 07 Oct 2024 06:20 PM - last edited: 07 Oct 2024 06:20 PM
@oj01 wrote:Only if you're in the market for an overpriced TV.
...or use Stream and your own TV of course 😄
