This discussion topic has been answered Discussion topic: All programmes have become HD and im unable to access them
Message posted on 19 Sep 2023 07:15 PM
Viewing programmes an hour or so ago with no problem, now all channels have been made HD, i haven't subscribed to HD and now i cannot view 89%of the programmes on sky, including terrestrial channels
Message posted on 19 Sep 2023 07:18 PM - last edited: 19 Sep 2023 07:18 PM
Can I suggest you try a ower down restart of your SKY Q box:
Use the remote to place it into standby mode
Then remove the power to it (either switch off at mains or remove the power plug)
Wait at least 30s
Then re-apply the power & wait for it to fully restart - this may take a few minutes.
Once the main box is restarted do the same power down onany mini boxes if needed
Wait at least 30s
Message posted on 19 Sep 2023 07:21 PM
Re: All programmes have become HD and im unable to access them
Normally if you don't have HD subscription it's the SD channels that appear first in the TV Guide and Most HD entertainment channels are in the 800 numbers.
Sometimes this can occasionally flip. Check in the guide in the 800's and see if you find the SD channels.
You could also try rebooting your Q box.
Message posted on 19 Sep 2023 07:26 PM
Thank you for your help, we're trying these suggestions now, fingers crossed one of them works
