Discussion topic: After trying to permanently delete programs from Sky 2gb box, the planner and program selection stop
This message was authored by: TonyP1964
After trying to permanently delete programs from our Sky Q box, the sky system seems to stop working and only rebooting by turning Q box off allows it to work again. I have downloaded latest software. Still not working
Re: After trying to permanently delete programs from Sky 2gb box, the planner and program selection
Hi @TonyP1964
There's no need to manually permanently delete - the space will be automatically recovered if needed.
Avatar for TonyP1964
Thanks for the quick reply. The reset didn't work either. I tried this three times. Nothing reset?
Reset didn't work. Nothing reset, not even remote
Ok but why have the option if it's not needed?
