Discussion topic: After power cut
This message was authored by: FJP342
After power cut
We have had several power cuts recently but the last one has resulted in only one channel and it says waiting to load the TV Guide.  We think it might be one of the cable connectors, have tried buying  new connectors but none seem the right size as think our cable must be very old....... any suggestions?? before we buy a whole new cable and send my elderely husband onto the roof!!
Re: After power cut
@FJP342
Which platform do you have, Sky+ or Sky Q?
Avatar for FJP342
Re: After power cut
SKY Q,   eagerly awaiting help
Re: After power cut
@FJP342
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
Re: After power cut
Satellite cable f-plug connectors haven't changed in 40 years so maybe you just bought the wrong ones?
