Discussion topic: Add Sky Q to a third tv
Message posted on 24 Jan 2024 11:37 AM
Hi. I have SkyQ boxes in two of my rooms at home with Samsung TVs. I would like to have Sky available on a third TV in the kitchen on an LG TV. Can I do this without an additional SKY Q box?
Message posted on 24 Jan 2024 11:44 AM
Re: Add Sky Q to a third tv
@tonytales wrote:Hi. I have SkyQ boxes in two of my rooms at home with Samsung TVs. I would like to have Sky available on a third TV in the kitchen on an LG TV. Can I do this without an additional SKY Q box?
I take it you mean you currently have a main Sky Q receiver & a Sky Q mini box? Yes, you can loan an additional Sky Q mini box for your 3rd TV - this normally incures a £50 admin fee, but no increase on your Multi-room subs.
Message posted on 24 Jan 2024 11:53 AM
Thanks for taking the time to reply. Yes, I have a main Sky Q box in the main lounge and a SkyQ mini in the kid's playroom.
Message posted on 24 Jan 2024 11:55 AM
@tonytales
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a 3rd mini box at the same time if you’re using it for one of the apps such as Netflix.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
Message posted on 24 Jan 2024 12:32 PM
Thanks @Daniel0210
