14
This discussion topic has been answered Discussion topic: Activate Netflix
This message was authored by: NJ3
Activate Netflix
Hi there. I just added Netflix to my Sky TV package however there is no option for me to sign up as a new customer to activate Netflix
Re: Activate Netflix
@NJ3
Sky says:
  1. Press Home on your Sky Q remote then scroll to On Demand
  2. Scroll to Netflix and select any Netflix show
  3. Follow the on-screen instructions
https://www.sky.com/help/articles/apps-on-sky-q-and-glass-using-netflix
@NJ3
Sky says:
This message was authored by: DavePoole
Hi
i have the same issue. When I get to Netflix I only have the option to join or sign in, not activate. Had long calls with Netflix and Sky, but neither have been able to sort it out (yet). This has including doing:
- reset apps on hidden menu
- numerous power off cycles
- leaving it overnight
- unlinking old Netflix acc from family
Any suggestions welcome please!!
@DavePoole wrote:
Hi
@DavePoole have a look at the link below if you have not already tried that. When I got Netflix through Sky I received an activasion e-mail
https://www.sky.com/help/home/sky-apps/tv-apps-on-my-sky-q-box/articles/apps-on-sky-q-and-glass-netf...
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: slipd
Hi guys,
Until the recent Netflix account sharing purge, my Dad has been using my account. But now he's signed out... he has Netflix on his Sky account but the initial activation emails would have been long since deleted - anyway of still sorting out his own account?
Many thanks!
This message was authored by: Drummunkee
Hi, did you ever get this sorted? I've just signed up and have the same issue...
thanks
Yeah, he's on it now. Afaik, he just got in through the Netflix app on his Sky Q box... I don't think he even needed to provide any credentials? It's still showing on his Sky account, I've just logged into it.
What issue are you seeing?
This message was authored by: stardak
Did any of you guys have a message appear advising that you already have netflix as part of your sky package?  I've been on the phone multiple times with sky and still not got this sorted.  I've changed meials, etc.
Don't recal hearing anything from my Dad on the subject... will have to check.
If you need Sky Support though, try going through their WhatsApp chat. I've used it twice now and they've been excellent. You can start it off through automated phone support 😉
This message was authored by: Shib1
Did you ever get this fixed? I'm having the same problem and sky haven't gave me a activation code or anything
Nope, ended up cancelling it off and just buying Netflix direct and it worked
@Shib1 wrote:
Did you ever get this fixed? I'm having the same problem and sky haven't given me an activation code or anything
They are only supposed to send it after you get to the 3rd step (something like that) on the process linked above. Did you start that first? Do Sky have the right phone number for you?
This message was authored by: doylesi
I'm having similar issues. I switched from BT TV to Sky, both of which include a Netflix subscription. I thought I'd done everything to activate it on my TV but Netflix say my account is not linked to Sky and are now charging me a separate subscription.
This message was authored by: Rose1011
Netflix is still not working
Still? This is the first time you've posted in this thread? Or in the forum generally.
What's the history of your specific problem?
