Discussion topic: Accessing Eurosport on Q box
This message was authored by: Reedie19
I have a premium package direct with Eurosport.  I don't have Sky Sports.  I'd like to add my existing Eurosport package to Sky, so I can make recordings.  Is this possible?
Re: Accessing Eurosport on Q box
@Reedie19  No but you can view and record Eurosport channels on 413 and 414 via Sky Q as the channels are part of the base tv package (not sky essentials)
Avatar for Reedie19
Thanks for the rapid response.  I can't access it on Sky; I just get the alert 'You don't subscribe to this channel.  For upgrade information view in full screen'  I don't want to upgrade as I've already paid the subscription to Eurosport.  I'm hoping I can view what I've already paid for via Sky.
Hi @Reedie19   It is not a SD/HD problem is it? Are you trying to view HD without a Sky HD subscription.
@Reedie19 what Sky subscription do you have ?
As others have mentioned Eurosport is a non-premium channel on Sky, included in the basic Sky Signature subscription. You don't need Sky Sports to view it. What Sky package do you have?
Avatar for Reedie19
Thanks all for the responses, much appreciated. I just have Sky essentials, so I'm not entitled via Sky to view Eurosport but I hoped it might be possible to port it across as I've already subscribed to Eurosport.  If that's not the case as I don't need any of the Sky channels I may be better to drop Sky and get a freesat box where I can port my Eurosport as well as the other apps I use.
