Discussion topic: Accessibility on Sky Q
This message was authored by: PJ+Lister
I have a message on my screen which says 'Accessibility on Sky Q' which asks me to go to Settings but when I press my remote nothing happens and it doesn't send me to settings
Re: Accessibility on Sky Q
Exactly what are you doing when you get this message @PJ+Lister
To Go to Accessibility you need to go to the Home menu
Home - Settings - Accessibility
hi @PJ+Lister
we beleive the following may help
Press & hold the 4 & 6 together until the red led above the SKY logo buttn flashes
this sets the remote to use Infrared only so now make sure you point the remote at the box  to dismiss the message.
Once you pass that Press & hold 1 & 3 together to re-pair back in bluetooth mode
If that doesn't work,  may I suggest you try a  full reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Again see if you can dismiss the message, making sure you point the remote at the box
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
