3
This discussion topic has been answered Discussion topic: Access to 4seven channel
This message was authored by: theblues
Trying to watch the AFCON tournament on channel 4seven but it says I have no satellite signal but do on every other channel except E4. How do I get access?  Txs
Re: Access to 4seven channel
@theblues
With a “no satellite signal” message, check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely either;
▫️a dish misalignment,
▫️a failing LNB (on the arm of the dish),
▫️water getting into the cabling
so check the troubleshooting on this link
It may then give you the opportunity to arrange an engineer. If it doesn’t you’ll need to contact Sky to book an engineer appointment.
If you are connected to a communal dish you need to liaise directly with your building management company or landlord who will have their approved engineers to contact direct.
It’s worth mentioning that:
🔹 a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News),
🔹 wind and rain can affect the satellite signal and following adverse weather wait times for an engineer will probably be significantly longer.
🔹a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
▪️I AM NOT A SKY EMPLOYEE ▪️
Hi @theblues   Sorry, just to confirm no broadcast problems with 4seven (137).
Avatar for theblues
Hi. Yes. When I enter 137 it comes up with no satellite signal so can't watch AFCO football. All other channels except E4 work. Txs.
@theblues
Answered - Go to Answer
