Discussion topic: About volume controls on sky q
This message was authored by: Reuben4
I was wondering if anyone could help I want to get the sky q remote volume and mute buttons to work with the ULTIMEA aura a60 sound system but I've tried everything and can't seem to get it working maybe I should contact sky i don't know what to do though
Re: About volume controls on sky q
Are they HDMI connected and support CEC?
(if so, you programme the Sky remote to the TV and the TV sends volume commands to the  sound bar)
Avatar for Reuben4
Level 0 icon
Yes but I haven't got a free port on my tv
Not even ARC socket to sound bar?
Unless another remote code works then it's quite possible it's simply not supported.
How is the amp connected ? Optical?
