Discussion topic: Cannot get sky on two of my mini boxes
Message posted on 23 Apr 2025 10:57 AM
No sky connection on 2 of my tvs
Message posted on 23 Apr 2025 11:10 AM
Re: Cannot get sky on two of my mini boxes
Hi @Berta1
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini).
