Discussion topic: A remote for my bed room
Message posted on 09 Oct 2023 08:50 PM
My remote for my TV in bed room is broken
Message posted on 09 Oct 2023 08:52 PM
Re: A remote for my bed room
@Watermelon
If your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some troubleshooting and then it’ll send you to a form to request a replacement (apparently this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It might be quicker to purchase a new one from a retailer / main supermarket. If you do that as well you’ll always have a spare.
Hi @Watermelon
Try completly resetting your Bluetooth remote.
Failing this
Check the following link and it will lead to a form for a replacement remote.
