Discussion topic: A box
This message was authored by: Rach98
A box
Tv box is turning on and off and the no signal sign is shown up also
Re: A box
Hi @Rach98
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
Avatar for Rach98
Re: A box
But I've done all this and then when you go to press a button on the remote it turns the box off no matter what button you click
Re: A box
@Rach98
If you’re seeing a message displaying ”No signal” it tends to be from your TV, such as possibly not being on the correct input (check the HDMI cable between the Sky Q box and your TV)
Whenever a “no satellite signal” message is displayed, that relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight.
