Discussion topic: 401 or 407
This message was authored by: Mairi7
401 or 407
Unable to access channel 401 or 407 on main sky q but can get these channels on mini box
Re: 401 or 407
Try a power cycle on the main box.
Re: 401 or 407
hi @Mairi7
It sounds like you may not have the UHD subscription but seeing the UHD versions at 401 & 407 - if this is the case try looking at  channels 858 (for Main event) & 857 for Darts/F1 in HD
Although as @PandJ2020 suggest a reboot may sort it out
