7
This discussion topic has been answered Discussion topic: 4 K.
This message was authored by: Fidel+59
4 K.
So forgive my ignorance but I'm no expert. Right I've downloaded the House of Dragons in UHD on a cheap UHD TV. I'm about to purchase a flagship Oled TV.
(Sony A95L). Now when I plug my new TV into my Sky Q box will I get the quality of the cheap TV or will the new flagship TV enhance the picture accordingly?
Thanks.
This message was authored by: nigea99 Answer
Re: 4 K.
Thanks.
hi @Fidel+59
How much of a difference you will notice may be down to your own perception but my guess is that you will notice it
OLEDs definitely have some clear benefits - much deeper blacks & also do not suffer from off-axis drop off that LCD screens do.
I don't know the Sony TV personally but I seem to recall it has had some good reviews
Re: 4 K.
Thanks.
hi @Fidel+59
This message was authored by: Mister_Dalek
Re: 4 K.
Thanks.
Further to what @nigea99 says, I would also suggest you download the UHD HDR versions of House of the Dragon as these will offer a noticeable difference in image quality, especially on a top-end TV such as the Sony A95L which is extremely capable with HDR (High Dynamic Range) content.
The TV has a Netflix calibrated mode so if you use the app on the TV (rather than on your Q box) you will benefit from vastly improved image quality with many titles available in Dolby Vision (if you subscribe to Netflix Premium.)
Avatar for Fidel+59
Level 4 icon
Re: 4 K.
Yes the native Netflix app on my TV does seem to be better than the Sky Q Netflix app for some reason.
Re: 4 K.
We do recommend using the TV's inbuilt apps rather than via SKY Q
As @Mister_Dalek  says they usually offer Dolby Vision (with the relevant sub) and HDR 10+ (used on some Prime titles)  and more likely to be tuned to the TV
Re: 4 K.
The Sky Q box is really beginning to show its age these days. I always recommend people use other devices or their TV app to access Netflix. The apps on Sky Q are there for convenience and aren't necessarily the best quality. It can't output Dolby Vision for example or native frame rates, it being locked to 50 or 60Hz.
Re: 4 K.
The only problem you will have on an OLED @Fidel+59 is as already mentioned, the blacks are inky black.
We do not want you back here complaining dark scenes in a cave are so dark you cannot see anything until a dragon lights things up! 🤣
Was my post helpful or informative to you? Please give it a thumbs up/like.
If my post has solved your problem, great! Please click on "Mark as Answer" under it and share the love!
Avatar for Fidel+59
Level 4 icon
Re: 4 K.
There will be no complaints from me boyo ✌️
Answered - Go to Answer
