3
This discussion topic has been answered Discussion topic: 3rd part Broadband Yayzi Fiber
This message was authored by: SlackDarren
Currently with Yayzi fiber and the wife wants Sky., Want to stick with Yayzi as its 900mb So nice and fast.
Any problems or tips before i Join Sky ? To make the wife happy for christmas.
Very Kind Regards
Slack Darren
This message was authored by: Quoman7 Answer
Re: 3rd part Broadband Yayzi Fiber
@SlackDarren wrote:
Thanks for that, Am i correct that I could use ethernet cable if i wanted ?
Hi @SlackDarren Yes you can ethernet your SKYQ equipment to your router.
Should be no issue - just bear in mind Q will only connect via 2.4GHz band, you need to ensure the router allows for this (no steering for example).
Avatar for SlackDarren
Level 2 icon
Very Kind Regards
Slack Darren
