Discussion topic: 3 additional Sky boxes not working following an engineer visit
This message was authored by: Chris270
I can't watch any channels on the 3 additional boxes. Q box is working ok. Had engineer here recently who installed new q box.
Re: 3 additional Sky boxes not working following an engineer visit
@Chris270 Have you tried rebooting your main Q box ie
then
reboot each mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @Chris270
First reboot the main Q box.
When the main Q box is back up and completely running carry out a Network reset on the minis.   Start with the one nearest to the main Q box
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
