27 Jun 2024 04:03 PM
We have had Sky for years and recently 'upgraed' to Fibre broadband. Since the installation, the link between our SkyQ box and the other mini boxes has become flakey - as if the connections have become poorer. We have moved the location of the hub, but if anything it should now be in a better place....
Any thoughts? And yes, I have already followed the laborious self diagnosis processes that Sky provides, and nothing has worked.
27 Jun 2024 06:36 PM
Also have the dame issue. Looking for some info in hiw to resolve
27 Jun 2024 07:00 PM
Hi @Mick84
Don't know what procedure you followed. You don't mention it is Sky Fibre or 3rd party broadband.
Wait until the router is completely back and running and then carry out a Network Reset on the main Q box found in Q box Home - Settings - Setup - Network.
Once the main box is reconnected to your WiFi,
Then try a Network Reset on the minis. Start with the one nearest to the main Q box
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Failing all of the above you may need a Sky Q WiFi Booster to position midway between your main Q box and the minis and you will need to contact Sky directly.
