Discussion topic: 1st minibox does not work since having a 2nd fitted
This message was authored by: DawnFraser
Since we had a 2nd mini box fitted our first mini box does not work
Re: 1st minibox does not work since having a 2nd fitted
Any more detail, like what it does, where they are located, how they're connected, how you set the new one up?
@DawnFraser
Which main Sky Q do you have?
The original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes.
Good point. Forgot about that!
