5
This discussion topic has been answered Discussion topic: Sky protect app problems
This message was authored by: Drse
After charging my video doorbell and putting it back have found that it doesn't warn me that someone is approaching door. It records but I am getting no audible alarm on my iPhone which I was getting before can someone tell me what I am doing wrong
Avatar for Drse
Level 3 icon
This message was authored by: Drse Answer
Re: Sky protect app problems
@Drse when you are in the app click on the video doorbell then click on the cogwheel at the top right hand corner
under video doorbell settings click on the cime sounds and chech motion detection is turned on if it is check that the volume is turned on
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Drse
Level 3 icon
Sorry still not working
Avatar for Drse
Level 3 icon
Have sorted it thanks
@Drse how did you sort it in case someone else has the same problem
Avatar for Drse
Level 3 icon
I had to remove videodoor bell from app and chime and start again. Trouble was it took about four times and suddenly it worked. A bit worried when I have to take it down to charge it might happen again
