02 Jul 2024 07:13 PM
My router does not have an ethernet port. Is there another way to connect the chime doorbell?
03 Jul 2024 05:26 PM
@Smth17 afraid not it does need to be connected by ethernet. It's very strange not to have an ethernet port on a router can you post a picture of your router
04 Jul 2024 11:03 AM - last edited: 04 Jul 2024 11:03 AM
If you are using a WiFi-only portable cellular data 'hotspot' for the connection, you could consider replacing this with a dedicated 4G or 5G router: those do have ethernet.
