Discussion topic: Doorbell & chime will not sync
This message was authored by: Melr
Doorbell &chime will not sync.  Have new broadband provider and since I've changed the doorbell doesn't work. Camera, chime etc. linking okay but bell won't work, I have tried all suggestions to reset nothing has worked. Do I need a replacement doorbell?
Re: Doorbell & chime will not sync
@Melr  Your chime should just plug into the new router and work as normal. It does not work over Wi-Fi.
Firstly, you will need your chime to sync with your router by an ethernet cable from chime to router.
Restart your broadband router/ hub.
 The Chime must show a solid blue light before being able to sync, it will flash yellow for a short time after plugging in and while you place in the ethernet cable, then after that short time it should switch to a blue light.
If so no blue sync light shows:
  • Unplug the Chime.
  • Wait 30 seconds.
  • Retry by plugging in again to resync.
When the Chime is synched.
With the on/off switch on the back of the doorbell , switch off the doornbell and leave off for ten minutes.
Then switch on the doorbell and straight away charge the doorbell for 6-8 hours or overnight. Then try resynching to the chime.
