Discussion topic: sky mobile phone
Message posted on 20 Nov 2025 08:03 PM
sky mobile phone
I am a sky mobile customer and would like to change my devise
Message posted on 20 Nov 2025 08:08 PM
Re: sky mobile phone
You can swap or upgrade it, so this link will help you to do this:
https://www.sky.com/help/articles/sky-mobile-upgrade
If you don't want a new sim then make sure you select the "I do not need a new plan/sim" option.
If you are struggling with this then give Sky a call on the free 150 number to do it.
If sending a phone back to Sky then make sure you get and keep proof of delivery.
The device you send back will be inspected for damage and a final valuation will be given so if you still owe anything against it thye difference will be added to your next available bill.
