2
Discussion topic: privacy calls from mobile
This message was authored by fanarkler This message was authored by: fanarkler
how can i withhold my mobile number from all phone calls i make
This message was authored by 63johnw This message was authored by: 63johnw Answer
Re: privacy calls from mobile
Hi @fanarkler  you should be able to do it by dialling 141 then the number you are calling but there have been reports on here that this doesn't always work.
If someone has helped give them a thumbs up.
If their answer solved your issue mark it as the correct answer.
I won’t respond to direct messages so please post any problems on the forum.
I believe you dial 141 before the number you are calling.
