6
Discussion topic: making locals calls while in canada
This message was authored by Bill+again This message was authored by: Bill+again
 I amgoingto canada in july for 3 weeksand wish to use my phone out there. Can someone please simply answer the following questions
1.  Cani use it and how much
2. How much per day
3. can i phone/text uk and what does it cost
4. can i phone local canadian numbers and cost
5. does it automatically stop on returning to uk
its allvery confusing going through the "help" pages
thank you
confused
This message was authored by Ollos123 This message was authored by: Ollos123 Answer
Re: making locals calls while in canada
Posted by a Sky employee
@Bill+again
1. Roaming in Canada will cost you £2 per day.  For that you get access to your home allowance(s).  Any data you use will come out of your UK Data plan.  You can roll data from your Piggybank for free if you need more data, the same as you can in the UK.  If you have Unlimited Calls & Texts then any calls / SMS to UK destinations will be includive, as they are in the UK.  If you don't have Unlimited Calls & Texts then it'll cost you £0.10 per call / SMS
2. See 1
3. See 1
4. Calls to a Canadian number would cost you £1.75pm in addition to the £2 per day fee.  If you were to add International Saver to your plan (£3 per month) then calls to Canadian numbers would cost you £0.05pm
5. Yes
@Bill+again  All calls from a UK mobile number to a Canadian number even when in Canada  would be classed as international calls, not local, please see this link for charges https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
@Bill+again
As @GD1 indicates, typically you need a SIM provided by a telco located within the country you are in to be able to take advantage of 'local' rates.
Bill+again
Thank you
So what I got from that was
Price to ring number in canada is same as if I rang from here.
Get a local sim only for Canada calls
So what are answes  to questions 1, 2, 3 & 5 ?
@Bill+again  Please refer to the link I posted for answers to the other questions.
@Bill+again
2. See 1
3. See 1
5. Yes
This message was authored by Carly01 This message was authored by: Carly01
You can use your data over there, so it costs the amount what you pay each month in the UK plus an extra £2 a day for data roaming whilst there. My daughter is using the same method while she is in canada. Try to hook up to WiFi when over there then you won't have the £2 charge. It only activates when you use your data and not WiFi.
