Discussion topic: iPhone 17 pro 100mb
Message posted on 07 Nov 2025 08:16 PM
iPhone 17 pro 100mb
I'm looking to purchase the iPhone 17 pro with the 100mb eSIM as advertised however when I add to basket I can only progress if I select a different eSIM GB package which I don't want. Any ideas?
Message posted on 07 Nov 2025 08:20 PM
Re: iPhone 17 pro 100mb
100mb is a really tiny amount of data that can be used up in a few minutes if not seconds so if you are sure this is what you want then your only option is to call Sky to see if they can get this ordered with a physical sim.
Message posted on 07 Nov 2025 08:40 PM
The 100MB SIM is really only intended to receive 'piggybank' data rolled over from another mobile with a more generous data allowance on the same account.
