Discussion topic: iPhone 17 battery drain
This message was authored by: Dave+Plumpton
Have recently swapped my iPhone 14 for iPhone 17 as part of sky,s swap deal.
I have found that the battery drain is crazy and doesn't seem to hold its charge for any length of time.
ihave turned off various apps etc but this doesn't seem to help
any ideas or suggestions
Re: iPhone 17 battery drain
Check the battery breakdown - it shows you which apps are consuming the power.
