Discussion topic: esim to sim replacement help
Message posted on 16 May 2026 09:49 PM
Message posted on 16 May 2026 10:02 PM
Re: esim to sim replacement help
You don't get a plastic card for an esim so do you want a replacement plastic sim card or have you deleted the esim in error so you need one for this ?
Message posted on 20 May 2026 04:06 PM
The esim has been deleted and I want to convert to a plastic sim , im old and just prefer a plastic one instead
Message posted on 20 May 2026 04:19 PM
If you login to your account via the MySky app and go to the mobile tab then the sim that you deleted, there should be an option to reinstall it.
