Discussion topic: WiFi Calling not working
Message posted on 21 Sep 2025 07:27 PM
Hi all,
I've got a Sky eSIM for my Pixel 6, but WiFi calling is not working.
Other features like Visual Voicemail and 4G Calling appear fine, it's just WiFi calling causing issues.
Any ideas on how to resolve?
Previously it's been a case of the carrier turning it off and on again and that's tended to get it going.
O2 supports WiFi Calling on my device, so the underlying network shouldn't be the problem.
Thanks 🙂
Message posted on 21 Sep 2025 07:30 PM
Re: WiFi Calling not working
Did you buy the device from Sky?
Message posted on 21 Sep 2025 07:31 PM
Hi @SaltyW did you get your phone from sky ? If not then they don't guarantee phones not purchased from them will work with WiFi calling.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 21 Sep 2025 07:39 PM
Ah, the phone wasn't bought from Sky, although I can see it's using Sky's specific carrier profile?
sky_gb-72000000020.70 from 2025-06-05
Is there a way we can get Sky to try turning it off and on again? That worked with other carriers.
Message posted on 21 Sep 2025 07:48 PM
Hi @SaltyW you could try calling sky but getting to speak to someone who could help will probably be the issue you will face.
