4
This discussion topic has been answered Discussion topic: Weak signal
This message was authored by: kath1234
Weak signal
Hi,
Kath
This message was authored by: xenon81 Answer
Re: Weak signal
The signal bars are a very rough guide to signal strength but they date from the 1990s 2G era and don't take into account other factors. For example 4G is transmitted on different bands and if you're connected to a high frequency band you may only get 1 or 2 bars but have faster data than a low frequency band, which would give more bars but slower data. So don't worry about the number of bars too much.
Re: Weak signal
@kath1234
Your wifi signal is showing a strong, the one to the left with one block is the mobile phone signal so isn't anything to do with your fibre broadband connection.
Avatar for kath1234
Level 4 icon
Re: Weak signal
It is an iPhone 15 on Sky network. Why is it so weak, any idea?
Kath
Re: Weak signal
@kath1234
Presumably either because O2 (the cellular network which Sky Mobile uses) doesn't have particularly great mast coverage in that vicinity or cellular signal isn't penetrating the building you are in.
As @caesarome indicates, this is nothing to do with a 'sky fibre subscription' so I've moved your post to the Mobile forum.
Re: Weak signal
