Discussion topic: Voicemail pin
This message was authored by: Russ62
Voicemail pin
Need a pin to listen to the many Sky⁴ Voicemail messages that arrive in my mobile everyday.
This message was authored by: twilight+princess
Re: Voicemail pin
Have you previously set up voicemail incl a pin by long pressing the voicemail key (usually 1)?
Virginia.
I don’t work for Sky.
If I have helped then please leave a like.
