Discussion topic: Voicemail issue
This message was authored by Southwalker This message was authored by: Southwalker
Voicemail issue
About a week back I had a voicemail left on my mobile,it was one of those short no real message types,I've deleted from my inbox,but I have a persistant problem where everytime I boot up my mobile and for the time it's on it's still saying there is a voicemail waiting for me! but each time I check my mail is empty,how do I get rid of this notification? I'm using a Samsung Android
Re: Voicemail issue
Can you use a different device to leave yourself a voicemail and then delete it as it might then clear this other one ?
Southwalker
Re: Voicemail issue
You are a genius! I tried leaving a voicemail on my mobile via my landline,and then deleted it! it worked!! the notification saying I have voicemail vanished,so simple and I would never thought of it.
Southwalker
Re: Voicemail issue
Well that went weird, after a day or so free of the phantom voicemail,the notification has returned!! check mail and there is nothing there,but it just won't clear,I don't get it
This message was authored by mSTecher1995 This message was authored by: mSTecher1995
Re: Voicemail issue
hi, it can be some glitch in the receiving server, that can happen when some update is installed, it can be for the phone or the app, take a look on this post maybe can help you out https://eu.community.samsung.com/t5/mobile-apps-services/no-signal-after-software-update/td-p/919716... and try to remove the cache app or remove it completely and install it again, if you still face the same issue try to use another app like mailbox app https://null48.net/mailbox-app-android-free-download/ hope these steps help you out.
This message was authored by Stone34 This message was authored by: Stone34
Re: Voicemail issue
Go to Settings > Apps > Phone > Storage, then tap on "Clear Cache". This might remove any cached data causing the notification issue.
