Discussion topic: Vip customer data help
This message was authored by: victamat
Iff I'm a Vip customer and I'm in Germany will I be charged for using messenger or making phone calls back to uk
Re: Vip customer data help
@victamat
All customers have VIP status on their accounts.
Calls to UK landlines and numbers are included in your package so yoiu can make these calls as if you were in the UK. Calls to local numbers in the country will be charged at international rates.
For messenger it would need internet access so you can use your mobile data with a limit of 25GB per billing period.
@victamat
Yes, unless you are a Diamond VIP customer.
Everyone is 'VIP'.   Unless you are Diamond VIP then you'll be charged £2 for each 24 hours of roaming.
That will allow you to access your plan, including data and calls to the UK.
