Discussion topic: Using two Sky eSims on iphone?
Message posted on 05 Feb 2025 10:03 AM
Hi There, Im pleased to say the eSim conversion system is now working, however I tried to activate two eSims on my iPhone (with a physical sim in it too) but the iPhone is saying I need to disable one of the sims in order to install / activate the other?
Is it not possible to run 2x Sky eSims on the same iPhone?
Regards,
Mark
Message posted on 05 Feb 2025 10:07 AM
							Re: Using two Sky eSims on iphone?
I was under the impression that you can only run one eSIM alongside a physical sim, hopefully someone else can clear this up for you.
Message posted on 07 Feb 2025 01:16 PM
Ive found out this is an iphone limitation and nothing to do with Sky.
Regards,
Mark
Message posted on 08 Feb 2025 04:56 PM - last edited: 08 Feb 2025 04:57 PM
Apple says:
All iPhone models that support eSIM can have multiple eSIMs and use Dual SIM with two active SIMs at the same time.
You can use Dual SIM by using a physical SIM and an eSIM. iPhone 13 models and later also support two active eSIMs. iPhone models without a physical SIM tray support two active eSIMs.
https://support.apple.com/en-us/109317
