Discussion topic: Using to much data
This message was authored by: EL70
Using to much data
Iam housebiund but for zo me reason i am using all my mobile data can you explain this please
Re: Using to much data
@EL70
Do you have Wifi at home that you could use ?
If not then have a look at your device itself and in the apps to see what apps are using what data and then you can disable any that you do not use.
This message was authored by: Louise215
I keep running out of data each month. How do you get more they were saying the piggybank but if I click on to it it doesn't come up. Louise
@Louise215
The 'piggybank' stores unused data at the end of each month, so presumably you don't have any.
