Discussion topic: Using phone abroad
Message posted on 18 Jul 2025 03:05 PM
Using phone abroad
I'm travelling to Amsterdam tommorow and want to know if I'll b charged over the £2 a day or if there is other bills on top
Message posted on 18 Jul 2025 03:08 PM
Re: Using phone abroad
The £2 charge (for 24 hours) gives you access to your UK package.
However, you can be charged extra if you use it outside that allowance, such as calling local numbers (which are charged at international rates).
No, it should cost you £2 for each 24 hours use of your home allowance. You need to ensure roaming and mobile data are turned on in your phone settings and it will kick in when you send a text, make a call or use a small amount of data. Set any spend cap to cover the total number of days you are there. Remember that calls to local Dutch numbers are charged extra at international rates.
