Discussion topic: Using my sky piggybank data abroad
This message was authored by: R4RAD
I am travelling to Greece and want to know if I can use my piggybank data to access the Internet if there is no WIFI
Re: Using my sky piggybank data abroad
Hi @R4RAD  the roaming passport costs £2 per 24 hours and that lets you use your home allowance and piggybank if needed. You can't just use your piggybank without activating the roaming passport. That kicks in automatically if you make a call, send a text or use a small amount of data. Calls to local numbers are charged extra.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
@R4RAD
Be aware of what they call accidental roaming whereby you connect to a nearby Albanian mast if you're near the border and you'll incur lots of charges.
See the bottom of this link
https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
