Discussion topic: Using my phone in USA
This message was authored by: Lisa0809
How do I add data roaming for using my phone in the USA & only applying the daily charge?
Re: Using my phone in USA
@Lisa0809
You don't actually need anything other than to turn on mobile data and roaming via your phone's settings. The charge is £2 per 24 hours and this allows you to use your phone as if you were in the UK, mobile data is limited to a maximum of 25GB. Calls to UK landlines and mobiles are included but calls to local numbers are charged at international rates.
