Discussion topic: Using data in Italy
This message was authored by: Ellie9595
Using data in Italy
Hi, my data is not working in Italy. I've turned on data roaming and the network is correctly showing italian options. I've removed the spending cap and manually rewrote the information in mobile network settings. Not sure what else to do. I've bought an esim from Airalo to use in the meantime but that's not working either. Thanks
Re: Using data in Italy
Hi @Ellie9595  to try and get you some help I have escalated your post to sky so look out for a coloured speech bubble on here inviting you to a private chat.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
This message was authored by: Lisa-P1987
Thanks for escalating this. We’ve sent an invite to chat.
Lisa - Sky Tech Team Expert
This message was authored by: Gcamcv
Hi I have a similar problem and can't seem to get my mobile data to work in Itsly. It worked in Switzerland but has stopped Grainne
