Discussion topic: Using another ESim while abrosd
This message was authored by: AK671
Hi I am travelling to New Zealand and I am a Sky mobile customer with an eSIM, I want to be able to use my phone with a NZ e sim too, is that possible?
Re: Using another ESim while abrosd
@AK671
That depends on the handset model: dual eSIM functionality is a high-end feature.
Avatar for AK671
Level 0 icon
Thank you I have an iPhone 17. Would Sky be able to unlock it for the duration and I could use an actual sim?
NZ is a roaming passport plus location.  Whether £2 per 24 hours is acceptable is up to you...
Of course, using another SIM means a different phone number if you want to accept incoming phone calls...
Phones purchased from Sky are not network locked.
@TimmyBGood wrote:
@AK671
A quick Google says that iPhone 17 supports dual SIMs with either 1 physical and 1 eSIM or 2 eSIM...
Avatar for AK671
Level 0 icon
Thank you the other sim would  be a NZ number and just for local use. I woukd still retain my
own number using WhatsApp etc
Avatar for AK671
Level 0 icon
Thank you I appreciate your input
Sure - just ensure the Sky SIM doesn't connect via cellular as there's potential for the RPP to be activated...
