Discussion topic: Using WiFi in spain
This message was authored by: Gail18
Using WiFi in spain
I'm using my phone in WiFi mode . The phone has data roaming off. Why are sky charging me £3 day? Thanks
Avatar for Gail18
Re: Using WiFi in spain
I meant to say £2 day
Did you turn data and roaming off before you left the UK ?
Have you made any calls or sent any texts as doing either will trigger the charge ?
The charge is £2 per 24 hours.
Put your device in airplane mode (you can still use WiFi).
This will ensure you do not connect to cellular (which will potentially charge you).
