Discussion topic: Upgrade phone without a data plan
This message was authored by Blooblah This message was authored by: Blooblah
I'm trying to upgrade my phone and last week there was an option to choose 'no data plan', which has now gone. I have lots of data in my piggybank and was planning to use that and keep the same sim/number. I rang Sky to make sure that was possible and they said, yes. However i'm now unable to do it in the upgrade process - is it possible?
This message was authored by 63johnw This message was authored by: 63johnw
Re: Upgrade phone without a data plan
Hi @Blooblah  yes it should be possible, clear your browser cache or use a different browser and make sure you are logged into your account when trying. If you still can't then sky should be able to do it for you on the phone.
If someone has helped give them a thumbs up.
If their answer solved your issue mark it as the correct answer.
I won’t respond to direct messages so please post any problems on the forum.
