Discussion topic: Upgrade phone and keep the data plan?
This message was authored by: AlanS1985
Hi
My contract is currently up and I am due an upgarde on my phone. Does anyone know if this means taking out a new data plan or will it just continue the only I am currently on?
Kind Regards
Re: Upgrade phone and keep the data plan?
@AlanS1985
You can keep the current plan you are on unless you want to change this as well but if you don't then you can just place the order upgrade for your device.
Avatar for AlanS1985
Thanks for the reply.
If I select a new plan will it auto cancel my old plan?
You need to be careful when doing this as it is quite easy to accidentally order a new sim so you would be paying for two so if you do upgrade your data plan you do need to make sure it is applied to your current sim by selecting the "I don't need a new sim" or "keep my current sim/number" option.
