Discussion topic: Upgrade mobile plan
This message was authored by: Little+Maureen+Ed
Upgrade mobile plan
Why will it not allow me to upgrade my mobile plan
Re: Upgrade mobile plan
Hi @Little+Maureen+Ed  can you explain a bit more ? Are you using the app to change your monthly plan or are you choosing a new plan from the website ?
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Avatar for Little+Maureen+Ed
I have tried through the My Sky app.
If you can't do it then call Sky on 150 as they will be able to help you with this.
