Discussion topic: Trying to connect gla250 2015 to my phone
This message was authored by: Tp111
Dns not found error, I can connect via bluetooth for audio and calls, its just the internet doesnt work. Any one know of a way to fix this?
Re: Trying to connect gla250 2015 to my phone
Have you used the network settings:
Name: Sky Mobile Internet
APN: mobile.sky
Avatar for Tp111
Yes I have used the default internet settings from sky mobile. I can connect for audio and calls but not for the mercedes apps.
You might get better luck posting in a Mercedes forum.
However, in my previous cars (BMW/Audi) you cannot use your phone to tether internet access.  (You have to use the car's internal SIM - which probably requires you to have a subscription)
Avatar for Tp111
Ok
